Root [MetroPCS/CDMA] Widget picker installation help
mike28
Android Expert
What's up s3 heads does anyone remember about widget picker which we used on the esteem which gives you options on installing widgets using different launchers like the calendar app which is nice but it's only available with touchwiz I try to put it on system app using root explorer but it didn't work by any chance has anyone try this option yet or if it even works in the s3 this is the xda link thanks to the devs that put it together
http://forum.xda-developers.com/showthread.php?t=1575982
Well this is the thing the picker is nice but it does not gives me the option of using the regular calendar size that I want it only shows the small calendar option also the weather option that comes with touchwiz is not available I wonder what if there is an option for it
Yeah i just noticed that too, im also trying to get weather option also, if i find one i'll post it up.:-)
