Mi Band 7 has problems pairing to One Plus 6T
Amarkit
hi everyone
Newbie here so not a problem to post but a solution to a problem others may be having
I have just sorted out a problem where a friend with a Mi Band 7 couldn't get to pair with his One Plus T6
This fitness band paired with my phone (Nokia C21) OK but not his
Without going into the long and the short of it except to say that when you tried to pair with the app (Mi fitness) it just stayed on "searching" when you tried to get it to find the band.
So, the fix seemed to be..........
When it is stuck on searching just leave it there and do a factory reset on the band, as it restarts it will now be detected. That's it.
