Hey,
I tried to install an official Huawei update and therefore I had to format the device. Ever since I did, my SD Card seems to be corrupted. Under Android it is not always available, almost seeming like a loose connection. When I put it into my laptop it is write protected, so I can't format or do anything else. I tried under Windows and Linux. Also tried dosfsck -a... The switch of the adapter is definitely not locked. Also tried another adapter.
My phone doesn't work properly anymore and all the apps crash, when I use the card. Is there any way to fix this?
Thanks
Thanks
