<a href='https://androidforums.com/attachments/123382/'>View attachment 123382</a> im doing a data test on the 400gb card before i put it in (takes about 4 hours). but the phone should be able to use 400gb.
OK Card is legit. The Note 8 recognizes the card.
<br>
<br> this entire process took a bit over 6 hours because the program wrote a file to the card to fill it up then verified the data to make sure all the bytes can be accounted for.
<br>
<br> see photos. they show how it was written with files to fill up the capacity and were verified. the format on the windows machine and the format once the note 8 got a hold of it.
<br>
<br>
<a href='https://androidforums.com/attachments/123395/'>View attachment 123395</a>
<a href='https://androidforums.com/attachments/123396/'>View attachment 123396</a>
<a href='https://androidforums.com/attachments/123397/'>View attachment 123397</a>
<br> That's awesome!
<br>
BlueRay is Usually around 8GB. I think SD is like 700MBHave you seen how big a file size a Blu-ray movie is?
<br>
<br>
<br> YUGE!
How does the system use the external storage? Does it default to filling up its internal storage first? Is internal faster than external, or is it all just storage and it would be completely transparent to us?
I bought my card from Amazon.
Here's the link, right now it's $249 for the 400GB card:If I remember right, didn't another thread say 250 ish? I'm old and could be wrong.
