Micro SD Card Problem.....Help?!
DDokken
First I have a Kingston 32 gig Class 6 Micro SD card for my Tablet.
The problem I am having is with video files on the card. I can put the videos to the card but when I try to use the card to play the files they will not work. I should note this is either with the tablet or my laptop. The files are fine when run from other sources on the same devices.
Confused by this. Any ideas???!!!??:confused:
