Help Micro SD card won't fit
Might sound silly, but have you tried flipping it over? Sometimes I get the orientation messed up myself.
Is there any additional information you can provide?
~ ArmyX
Tried both ways unfortunately. The little plastic card that came in the slot to prevent dust is a little smaller than the card that is real.
It just seems that it COULD fit in there, just one little edge of the card that won't make it.
It should fit. The words should be facing up when you try to put it in. When I put an SD card in my prime I had to put a little extra force into it, but not much. If you can't get it in at all I would suggest calling asus to see what they say, or try a different card
The card doesn't fully fit in there, flush. When its "in", like you said, a little part of it is still sticking out.
Its very awkward if you have a naked Prime, but with a case, you should be gtg.
