andrew1994
Hey guys, not sure if this is in the correct place or not but anyway;
I bought a S5 at long last, it was bought brand new from a shop so there should be no problems with it, I've currently had it for three days.
The phone is working fabulously until I installed a Micro SD card into it. The SD card is not automatically mounting, when I go into setting > storage > SD section I press mount SD card and get "Preparing SD Card" -> "Blank SD Card, unsupported file system" or something to that effect. I have tried formatting the SD card on my PC to FAT32 and NTFS and this has changed nothing, I have done a factory reset and still nothing, I'm currently factory resetting the phone and upgrading it through Kies incase its a software problem but I'm beginning to wonder if I've been sold a dud phone, the phone registers that there is an SD card present, but just doesn't format the card when I attempt to do it on the phone, when I press format it says "checking card" and then I'm greeted by the "blank SD card" problem again.
Any help would be absolutely brilliant, if you need more information don't hesitate to ask as it's driving me bonkers!
Thanks in advance
Thanks in advance
