kapooram2013
My SanDisk micro SDhc 32 GB card not working. When I plugged it with my pc it show a pop-up for format but it fails and it shows only 30 mb of storage and it's format is RAW ....pls help me
Either you've got a fake or duff micro-SD card, where did you buy it? Or have you been using it as adoptive internal storage in a phone or tablet? If so the PC won't be able to see it. And it may appear as RAW, because Windows can't read and mount the encrypted EXT4 format that Android uses for adoptive internal storage
More information about Android adoptive storage here...
https://source.android.com/devices/storage/adoptable
When external storage media is adopted, it’s formatted and encrypted to only work with a single Android device at a time.
Whether the card is set up as adoptable (internal) or removable (external) is still in question.
-- If the former I'd just buy a new card, it sounds like the card has simply failed. Being only a year or so old it's not likely but not unheard of.
-- If the latter you might be able to use the 'chkdsk' command on a Windows PC to repair the card enough to copy off your data. In this case, if that does help, you might want to re-format the card and continue using it but microSD cards are relatively inexpensive to replace so weigh your options.
