micro sdhc card problem
aliengenx
I have a sanei n10 tablet and i hot a micro 32gb sdhc card .i put files on the tablet they play perfect i put the same ones on the card n the device says it cant play the file type is there anyway of sorting this as i ned it soon :)
Where did you purchase the sd card? If it was online I strongly suggest first testing the card out. ( I myself got a fake card on ebay once, modified partition tables ). Try this small program out : https://dl.dropbox.com/u/65761686/h2testw_1.4.zip
If all is clear,
check out SDformatter downloadable from their website: https://www.sdcard.org/downloads/formatter_3/eula_windows/
(let it run the full overwrite method to test all file clusters)
If all is clear from there, then , next steps would be device related.
Are these files in a language with special characters that might not work on a FAT32 filesystem? An easy test is to rename the file using only ASCII characters and a 3-character file extension that's appropriate for the particular file type.
