Microphone help
sh4d0w1021
Today my shatter shield was peeling to the point where 20% of it had come off so I ended removing the whole thing. After 5 hours of goo gone all of the residue is gone and everything seems to function. Except the voice mic. Using a mic testing app it seems to work for 3 seconds and cut out until it here's no sound and it will work for 3 more seconds. I fear I may have got goo gone or adhesive in the mic but I can't see down into it . I have tried a vacuum as well as a can of air none of which worked . Does anyone have any experience with a similar issue? How was it resolved? Will it dry out and work? Thanks everyone
Turns out that it was googone in the speaker. Used rubbing alcohol and a hairdryer everything works fine now .
