Help Microphone
bonne
Microphone on Nexus 7 works sometime does not work.
When I record something and turning the Nexus around, I hear scratches, rattles and other noise. As if the mic is loose or something.
Anyone experiencing similar and maybe knows a quick fix?
Regards, Lars.
Are you recording while turning? I just tested it and records fine, no rattles/scratches after recording something.
