Mini Keyboard help!
Hi, just bought an M8 android tv box and it came with a Rt-MWK08 mini keyboard.
I plugged the adapter into a usb port on the back of the M8 and turned it on. The mouse tracker works fine, but theres no text input from the keyboard. The right mouse button acts as a return, none of the other keys do anything. The transmit light on the unit comes on when you press it but nothing happens.
Do I need to change any settings on the M8 to enable the keyboard, or, am I missing something else?
Standard remote for the M8 is useless and inputting text with it as a royal pain...
