Mini PC Android navigator flash problems
hanzofm
Hi
I have not found another subforum best for this so sorry if it goes here
The mess, I recently purchased a mini dealextreme media center pc tv for android,
OS Android 4.0.4
Chipset BOXCHIP A10
Processor Frequency Cortex A8 1.2GHZ
RAM 1GB DDR III
Internal Memory 4GB
This is information that gives me TVBox
Kernel version: 3.08
Android version 4.04
number of compilation: crane_tvbox-eng 4.0.4 IMM76D 20120714 test-keys
The issue is that the tvbox in question does not go bad just that the web browser is closed every few minutes when I open pages with Flash content
Keep a android 4.0.4 I tried with several browsers, dolphin, firefox ... all the same when I open a page with flash, hangs and then displays the application has stopped working and closes
I tried a couple of things:
Uninstall the Flash plugin installed by default leading (v11)
factory reset the pileup erasing all
Do not look any hardware problem, it's actually quite powerful and the websites should move smoothly
Let's see if anyone can give me any advice on what I can do, because if you do not return or
