mini-SD card and Oovoo problem--!!! Mid 9742 Android 4.0
cailuqin
Hi, everyone
Got my mid 9742 two weeks ago, very happy with video, audio and 9.7'' size. However, there are 2 problems bothering me, I am the first time android user, not sure is tablet's problem or not.
1. mini SD card. I bought a 32 g mini sd card, mid 9742 recognized it right away, but when I tried to copy a picture from the internal storage to the mini SD card, it won't work. However, it seems I can copy somthing from mini SD card to the internal storage. I use ES File Explorer.
2. I am so happy with mid 9742, I bought two of them. I use them to try oovoo, when I use one to call the other, both of them will make "chiping" sounds but no showing live picture or voice.
Again, I am the first time android user, These are probably not tablet's problems. Thank you very much if anyone can help me fix these problems.
Hi, everyone
QUOTE]
Hi cailuqin
The miniSD card is called a microSD card
Sounds like your microSD card is set to ReadOnly ( needs to be set to Read/Write)
What Name microSD Card?
What Class microSD Card?
Also, please take time to explain how you are trying to copy to and from.
Example - Is the microSD plugged into your tablet or plugged into your computer?
If the microSD card is plugged into your computer Using an Adapter ,
take a close look at the Adapter amd make sure its no the the LOCKED position
(there is a little slider on the side of the Adapter)
if the Adapter is locked position, slide to the Unlocked position.
(push the slider down to make it Read/Write).
ALSO, more discussion on the MID9742 can be found HERE:
http://androidforums.com/general-tablet-talk/527241-coby-kyros-mid9742.html
I talked with Coby support, they told me the current solution for micro SD card problem is to connect the tablet with a PC, the internal storage and the micro SD card will appear as two separate removable drive in your pc, then you can move files around. Well, it's better than nothing, but I hope they can fix the problem and allow tranfer files between the internal storage and micro SC freely without the PC.
It is so annoying, even their mp4 player can transfer files between device and micro sc card but tablet cannot.:mad:
