gwcaton
Android Expert
Ok , don't know if anyone would be interested but here are some Minimalistic text battery widgets I have made that I thought I would share . Plus I am trying to figure out how to use MyDropbox .
I think you will have to extraxt the zip file and transfer the individual files.
If I figure this out all you will have to do is download and put in your Minimalistic text preference folder on your phone. then you can use as is or edit colors/background etc to suit your need.
You will also need to dowload the font files into your fonts folder on your sd card .
zip file of the MinTxt pref files - http://dl.dropbox.com/u/15569282/mintxtpref.zip
Links to the text icons you will need in your font folder on your sd card - http://gwcaton.deviantart.com/#/d4l1gpg
