Mirroring not Built-in?
If you don't have the Roku app on your phone try that:
https://play.google.com/store/apps/details?id=com.roku.remote&hl=en
Also, Samsung usually includes the feature in their products. Is there a 'Screen Mirroring' option in your Settings menu? Or the following links might help:
http://www.samsung.com/uk/support/t...with-my-samsung-tv-and-samsung-mobile-device/
Smart View
http://www.samsung.com/uk/support/tv-audio-video/how-can-i-view-my-smartphone-screen-on-my-tv/
Quick Connect
http://www.samsung.com/uk/support/mobile-devices/what-is-quick-connect-and-how-do-i-use-it/
Smart View
Quick Connect
Thx. The Roku app can be used as a remote for the player. It does not do cast/mirror. In this phone, there is no setting/feature. It's probably in higher priced models.
Yes. Works like a charm by Tree Team
@Unforgiven (What phone and app are you using?) I just tried the above app. On my Roku, I can the pear icon, Start..., etc. screen, but it does not get any further and then quits.
EDIT: Both my Roku and phone are on the same network. i.e. Connected to the same router. Again, I think this phone does not have Miracast built-in. And, this is why these apps do not work with this phone. These apps are essentially a shortcut - they streamline the process on phones that have Miracast.
I don't have a ROKU or use the app. I was just adding a link to the app @Dannydet referenced for your convenience. I personally have an Android TV with casting built in.
I can only suggest All connect, from the play store, but I don't think it mirrors the phone screen.
Your roku needs the app installed also for it to work (Miracast)....
