Misfit Vapor - Steps
morty_mma
Hi,
I have a misfit Vapor and happy with it so far..
Although I want to put the Misfit Steps on the face NOT the google FIT as the google fit seem to be less than the MISFIT..
Any ideas?
Cheers
Morty
You should be able to manage the watch face using the wear app on your phone. I looked in the play store and didn't see anything for wear devices. Is this something that came with the watch?
Hi yeah tried that and can only put on google FIT steps not the MISFIT ones :(
Unfortunately, smart watches in general are not taking the world by storm ... as a matter of fact, it's barely a drizzle. Add to that a watch like the Vapor isn't all that well known and you're not likely to find many other users in a general forum. Does Misfit offer any kind of support or their own user forum?
Also, thinking about it a little, maybe you have to make their "steps" app the default fitness tracker instead of Google Fit to have access to their watch face. :thinking: Without having one to check out all I can do is guess, though. Sorry.
