G
Ghostshifu
Guest
If you are looking for an application to replace the stock music player, look no further. The widget is very useful and good looking in any of the three widget sizes. The UI is very fluid and easy to use. All the options you would want such as shuffle, party mix and playlist are very easy to find and use. This player will also suggest songs to add to your playlist based on the "mood" of the music. It will also take care of almost any missing album art and information. All in all it's worth grabbing next time ofyou surf the market.
