Help mm-qcamera-daemon in 5.0 Lollipop camera issue
icedtea
anyone here having camera issues on the above?
upon opening the cam, it just goes blank/blank.. i need to reboot unit everytime.. then upon checking battery stats, top app usage is mm-qcamera daemon..
unit is unrooted with lollipop OTA update.
viber / wechat / fb msgr are installed..
already did:
wipe cache partition
stop start cam app | clear data/cache of cam app
Thanks. but to no avail. tried this.
i tried to revert the apps/settings i did before this happened frequently.. sad to say none of them worked..
tried removing some apps / getting back to previous launcher / deleting FB msrg .. .but still, as per checking time to time, upon opening the cam app, still shows the blank/black screen. . no choice to to reboot :(
