Help MMS doesn't work
jonnoboyd
Hi,
I can't seem to recieve or send pictures on my GT-19000. When I try and send one it just stays as 'sending' but never actually does, and when I am trying to recieve one it just stays as 'downloading'. I'm pretty sure my APN settings are correct, however I'm pretty ignorant with this stuff so I might be missing something obvious. Just to describe it though: in my Access Point Names folder are two options. One is listed as Virgin Internet, and the other Virgin MMS. The former has a green circle next to it indicating it is selected whilst the latter doesn't have any selection circle, and you can't seem to select it. I called up Virgin and they told me they were going to reset the APN settings or something, and to turn my phone off and remove the battery and sim for 15 minutes. I did that but it still doesn't work...
Here are the settings for the APNs:
Virgin Internet:
Name - Virgin Internet
APN - virgininternet
Proxy - 202.139.83.152
Port - 8070
User name - Not set
Password - Not set
Server - Not set
MMSC - Not set
MMS proxy - Not set
MMS port - Not set
MCC - 505
MNC - 02
Authentication type - PAP
APN type - internet
Virgin MMS:
Name - Virgin MMS
APN - virginmms
Proxy - Not set
Port - Not set
User name - Not set
Password - Not set
Server - Not set
MMSC - http://mms.virginvibe.com.au:8002/
MMS proxy - 202.139.83.152
MMS port - 8070
MCC - 505
MNC - 02
APN type - mms
Thanks for any help
I've always had the same problem with my Galaxy S. I'm on O2 and the problem has existed on both my devices.
As I said on the O2 forums, I'll not particularly fussed as MMS messages are expensive to send anyway.
