mms maximum size :: how to set?
mitral
Hi :)
(probably this have been asked a lot here, before, but I didn't found it)
I'm new to android and I've discovered that, when I send a mms with a photo attached, the message is sent with a photo with around 200Kb.
I would like to know how can I configure my messaging application so it reduces the photo to a smaller size.
Some help would be great.
Thanks
Alberto
Hi :)
Thanks
Alberto
I think you will need to install Handcent, free from the Market, as this allows you to adjust your MMS sizes.
I couldn't find a way of doing it on the stock, built-in, Android Messaging app.
Hope this helps. :D
Hope this helps. :D
and, will it be possible to uninstall or disable the default messaging app from android? :confused:
of course. :) ( it seems to me that today is monday ;) )
I definitely know it's Thursday!
I live in the land of the Cheltenham Gold Cup and there's thousands of Irish race goers around here... all celebrating St Patrick's Day. :D
