Mobdro issue
Mckay89
Hey guys, I recently downloaded Mobdro on my s7 edge. After the download completed I scanned the app to be safe, but after that it wouldn't give me an option to install the app. I've deleted and re-installed Mobdro but all it say when I click on the app is unable to scan.
Anybody have any ideas?
Thanks.
No, it's apk file. downloaded if from their website Mobdro.com. This is why I scanned it to make sure it was safe. All I got was a message saying "unable to scan this file type". this left me with no option to install it after.
OK, I tried downloading it myself with my Android phone using Chrome mobile version, and the download failed twice, APK was truncated. Downloaded with a computer, and it was fine, copied to phone, installed and works. So I guess they got problems with their mobile version site at the moment. So if you got a PC or Mac handy, download it with that, until they fix their mobile stuff.
BTW no Google Play here, so it was a direct download from their site, and then sideloaded.
Thanks dude I shall give it go.
Really love this app......It's not available on the Google play site. You can only get it on their website.
I just downloaded the apk on my 2011 Toshiba Thrive running 4.1.2 Jelly bean and it installed easily.
What app are you using to scan?
Just done this now and it worked. Thanks for the help.
