Mobile Data Monitoring & Usage
kmahesh
Hi Everyone,
I had got a new requirement in Android APP.Can ayone suggest me whether the requirement is feasible or not.
The developed APP should be able to display all the installed apps(like FB,VB,Youtube,etc...) in the mobile.User can set a defined value(Mobile data in MB) until which he wants to use each individual app .(Say the user wants to use 300 MB for FB,he will set a value in the APP),then my application should be able to monitor all data that is flowing through facebook app.Once the user reaches the deined value,a notification should be sent to the user that he has reached the deined MB for the Facebook application.
In case, if the requirement is feasible,can you please suggest the best approach.
