Curtis1973
Android Expert
I will be uploading various system apps that I have personally modified over time. Applications such as framework changes,system ui changes and other. Each of these apps will require you to be familiar with the only rooting method we have at this time which is king root. It will also require you to understand and accept the dangers of of bricking,how to get out of brick using Odin and firmware. It will also require that you have a general understanding on how to apply the listed apps below to the system without a method available for flashing. Ways this can be done are via applications like Root Explorer. Straight copying of the applications overwriting the system apps. In cases like framework applications the device will appear to freeze for a second and then reboot. For applications like system ui the systemui.apk will in most cases force close after overwriting the original. A long press of power and selecting reboot will get the new system ui active. Always follow the instructions carefully given. I am not responsible for any issues you may encounter either by not following instructions properly or for any other reason. You know the risks and agree to take the chance. I will always try and help you recover which is fairly easy actually if you do encounter issues. Now with all of that said lets get on to some mods.
SystemUI.apk mod version 0.2 : This mod is first out of the gate as a simple beginning test mod that adds a centered clock in the status bar and increases the status bar icons to 100% alpha(the alpha decides how dim and transparent the status bar icons are..original value is 75%). Nothing more has been changed other than the clock alignment and status bar icon alpha.
-Instructions-
Download the apk to your device,be sure temp root is active,open a root capable file manager like root explorer and navigate to system/priv-app/SystemUI and overwrite the stock system ui apk with this one (rename to SystemUI.apk from the name given below). The stock one will force close and stay this way until you reboot and the new apk starts. Long press power and select reboot. Upon reboot you will now have a centered clock. Download is linked below with a screen of the centered clock.
I will be adding many changes to systemui.apk and possible changes to the framework apks as well as some jar files as I go along. So keep a tab on this thread for new additions.
-Instructions-
