Help More G2 network Issues...
Sere83
As I mentioned previously in my last thread my G2 has reception issues in my house. However I also have another problem now. When the phone cannot find any network signal, some times it doesn't reconnect to the network even when it comes back into range. Then I go to the settings to manually re-connect or sometimes the network selection screen pops up and just keeps searching despite being connected allready.
Any one else experienced this?
Yes same problem here. I go into some shops that seem to blank out the signal. I go back out and its stuck. I had to reset the phone once or keep tapping the network I am on to get it to connect again.
you could try putting the airplane widget on screen and if that happens just click it off and on.
