Milo Willamson
Android Expert
New thread for those who are wondering, here it is, almost a full year since I had it (purchase it on 11/11/24) through the main headquarters of Verizon. (My visit was okay, but they did not give me spit on the world for a case, but my sister gave me hers, was a few millimeters taller then mine, but when I did get the otter case fits perfectly, press-on protection glass, still I could use it without it).
Pros:
Well pretty great battery for an introvert like myself, able to make cell calls about every once a while pretty clear, can text whomever seems pretty well, with Whatsapp and Signal frequent useage with Gmail, Camera, VLC, Blue tooth (Widex hearing aids) over all with wifi sort of on most of the day, it is soild over all, drains over all maybe about twenty percent after fully charge, when turning it off and putting it away for sleep it does not drain much unless I have running apps in the bg. While some mobile background usage is in the apps, (Never care for data sharing with other cells in general, even though have wifi cut off as well as cellular data off) it feels legit, the weight and height of it was pretty hard to get used to overall, but the screen is size of a normal hat (stocking hat lengths) Amazing features to modify the colors and massive goodie bags that is on the cell over all.
Take away from it:
Heafty price about 1,900 over all through the store, the customer service reek of bad habbits and behaviors, Hate the default launcher, switch with Smart Launcher over all, a decent one. The feel over it when I sit it down and do a lot of texting with it, my hands phantomly feel the groove in it. (A lot of still mobile background data chomping away on apps, even though it is ugly sharable in general)
And:
My battery will probably die out in a spell or two, thanks with Accubattery though, but tbh I do not like the option switch for battery though but I wait for the next morning or until it gets down to about half to charge it again, so looking at a great two days worth of idle with it.. (Yeah I am part intervert).
Pros:
Take away from it:
And:
