Reviews Moto Edge Plus.
Milo Willamson
Extreme Android User
Pros:
easy accessable apps,
easy blue tooth connection with pronax hearing aids,
able to control anything with ease.
The design itself and can fit into giant hands like my own, easy to carry around, when you get used to the weight.
Does not drop any phone calls, or text messages.
Easy accessable.
Easy to pick up and basically find the reset, volume buttons easy on the default.
Wide screen, amazing sound, does not drop while streaming at all.
Cons.
Notice when charging sometimes, like I previously mentioned that most default plugs when a new device can over heat throughout enough of amount of time, but the battery super lasts a super long time, I generally keep my battery in between around 75% to around 69% it does not drop heep, even when playing Rusty Lake and Time Surfer right now, it does not drop so much I had to find a good enough of time to charge it.
Give this around 85% out of 100% though. Only time will tell on the super long range of users who use this every day for anything.
Pros:
Way lighter CPU,
and be able to control as much media frenzy we can all get attach with,
awesome notification light around the edge :)
White on black so perfect, so you can have it across the room and still be able to check it without checking it as much.
And with the weight, if you are so used to it, really easy to carry around in your pocket :)
But only if you were wearing denim pockets or sweat pants too. Sweatshirts are a plus, also I do not know about large coats, because I never wear them as much these days..
