Moto Z2 Play: How to enable System UI Tuner
In addition to Developer Options, there is another secret menu embedded in Android which can be accessed on the Moto Z2 Play. This menu is called "System UI Tuner" and gives you more options to adjust you status bar, Do Not Disturb mode, and more.
In order to enable this menu:
  1. Swipe down with two fingers to reveal the full notification shade
  2. Press and hold on the "gear" icon in the top right-hand corner until a slight vibration is felt
  3. Once enabled, the System UI Tuner options will be listed under "Developer Options" in the Settings menu
