Help Motorola Droid 2 A955 Screen Repair Guide
repairsuniverse
This written repair guide will help you how to disassemble your Droid 2. Screws for Droid 2 are hidden under cleverly designed stickers and quite hard to find. But with this repair guide, it will help you too take apart your Droid 2 safely, in a step by step manner and will give you a chance to replace faulty parts.
This guide should help you replace the following parts:
  • Motorola Droid 2 A955 Glass Touch Screen Digitizer
  • Motorola Droid 2 A955 LCD Screen Replacement Display
Tools:
  • Safe Open Pry Tool
  • T5 Torx Screwdriver
  • T3 Torx Screwdriver
Motorola Droid 2 A955 Take Apart Repair Guide:
  • Turn off your phone first then remove the back cover, the SIM, the micro SD and the battery as well.
  • Next, peel off the sticker placed on the bottom of the Droid 2 to reveal the hidden screws. After removing the hidden screws, gently pry off to remove the back end of the casing using a safe pry tool. Place the pry tool between the opening and run it along the edges of the phone to release the clips holding the housing in place.
Figure 1​
  • There are five (5) pressure contacts that hold the headphone firmly against the camera
