Motorola Droid Pro FAQ's
Status
Not open for further replies.
D-U-R-X
turbo drinker
This is a work in progress and, as such, if you feel that there is anything that needs adding, please PM a guide or start a thread in Private Chat With Staff with your suggestions.
Many thanks :)
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Droid Pro Tips & Tricks?
4. What are the known problems with the Droid Pro?
5. Forum related questions.
6. What is root?/What does being rooted mean?
7. How can I fix/replace my screen?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: First off, you should check these posts out: New Pro - battery life and other questions and Battery Life Optimizations. You do not have to follow all of the tips/suggestions, but the advice is sound and will help. Smartphones operate on a sort of spectrum. On one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Q: Are there any Droid Pro Tips & Tricks?
A: Check out this section: Droid Pro Tips & Tricks
Q: What are some of the problems people have with their Droid Pro?
A: Check out this section: Droid Pro Support & Troubleshooting
Q: How can I fix/replace my screen?
A: This thread has step by step instructions: How to repair Motorola Droid Pro screen
Status
