In order to install DJI Fly app, who knows how to change a Motorola Moto e 4G LTE Prepaid Smartphone (Locked) from 32 bit to 64 bit O/S?
In fact, I did your homework for you.
Here is the arm7 version of the app.
It should work on your device.
https://dji-fly.en.uptodown.com/android
This device should already be 64-bit, as are just about all new phones from 2020 onwards.
https://www.phonearena.com/phones/Motorola-Moto-E-2020_id11422
Appreciate your help!
As I learned from DJI support before, none of their existing version can be installed into 32 bit O/S phone.
The version you suggested, it is "Architecture in arm64-v8a". So, failed installation again.
It is 32-bit O/S, but the device itself is 64-bit ready.
You are correct.
Sorry about that.
I used the appstore, and it used to not allow downloading if the app was the wrong arm.
So I pasted the link thinking it was correct.
My bad on that, and I will be more careful in the future.
I did some checking, and it appears that there are no arm7 versions of that app.
If the devs are so lazy, then I would suggest using a different app.
That is, unless you want to purchase another device just to be able to run that app.
If it's a DJI product, probably can't use it without the correct specific app from DJI. Last year I borrowed a DJI Osmo gimbal, and that could NOT be used without the specific supporting DJI app been installed and running.
That's the problem with some of these tech products, their proprietary supporting apps may go away for whatever reasons, and the drone, gimbal, smart-watch, etc, becomes completely useless, and is only good for recycling.
