MotoTorch LED: Fantastic Impromptu Flashlight!
SqisSqis
The MotoTorch LED application (only for the DROID/MILESTONE phones) is a very handy and efficient flashlight application that literally only takes a simple touch to use. MotoTorch utilizes the DROID/MILESTONE's LED flash found near the camera as a handy on-the-go flashlight. This application comes with a 1x1 widget that you just tap and it turns on the Flash for as long as you need. To turn it off, you just have to retap the widget so the flame is grayed out. And, not only does this app work as a flashlight, you also have the option to use it as a strobe light for dancing, and morse code, if you're geeky enough to actually know/use morse code (heh, just kidding).
So, if you'd rather not carry around a bulky flashlight in your pocket or just too lazy to buy a keychain size, this application is very useful to turn your phone into a bright flashlight for your adventures into the night, with added Strobe light and morse code options for a little more fun with your DROID/MILESTONE.
-Reviewed by SqisSqis
