Mount Manage and Seagate Wireless Plus
cplloyd42
Hi,
Firstly, my apologies for the typo in the title of this thread.
Has anyone had success getting Mount Manager to mount a filesystem located on a Seagate Wireless Plus on the local sdcard?
I've been following the steps described in http://androidforums.com/threads/play-music-from-network-drive-no-server-needed.341866/, but so far without success. The app appears to recognize the SWP as it automatically loads file_type and dir_type options, and there is no error/problem recorded in the log file. However, the filesystem I have nominated on the SWP does not appear in my nominated mount folder. I have tried entering the IP address of the SWP as per the above link, and also used MM's navigation facility that allows me to select my desired SWP-located folder. Both give the results, as recorded in the log file.
If anyone has any advice or experience I would definitely appreciate it, as I'm running out of options to try.
Paul.
Samsung Galaxy Tab 7.7
Android 4.0.4
