Root mount path
ndex477
I recently rooted my LG P506 using SuperOneClick 1.7. Everything is o.k. except when i try to uninstall the preinstalled AT&T bloatware I can't uninstall it(using RootExplorer).
I was told to use mount -o remount, rw-t yaffs2/system/system and adb push RootExplorer.apk to system/app.
SuperOneClick and RootExplorer show the mount path as: /dev/block/mtdblock1 and the command line module gives me an error message saying: "adb not found" when using "mount -o..."
Is there another method to removing the bloatware with SuperOneClick?:confused:
Thanks very much in advance.
