If you are trying to make a backup of your contacts on your SD card, you can go into the menu of your contact manager and export the entire list. If you are wanting to move them there to save phone space, I'm not sure that's possible.
I hope this helps! If not, there are two avenues: You can re-submit your question with additional info the same way you submitted this one, or you can join the forums for a better back and forth exchange of info.
