You need to go to the Play Store and download any applications capable of performing this operation, the most popular being Link2SD. Some phones have their memory setup so this operation is not possible, you will have to try with your phone and see if it works.
Link2SD has a very intuitive User Interface, and is fairly simple to use.
Good Luck!
