Help Movies onto msd card
Hi, I have put five movies on my msd card of which I just dragged n dropped on to card they play ok
Then for some unknown reason my other movies would not play. There is plenty of memory left on sd card.
I have followed a tutorial on pavtube video converter, for some unknown reason ( of which I hope you will put me right ) when my movie file has been converted and sent to my output file ie micro card it will not play on my Samsung tab pro 10. :mad:
The movie is there but its empty. Am I missing something here??
Thanks in advance
Hi, apologise for not getting back sooner, I have been away. I tried all of your advice but to no avail, tried 2 different sd cards, tried a third and hey presto it works fine. I wonder what the odds are on getting 2 faulty sd cards.
Once again many thanks for replying, at least I have learnt a few things.
Kind Regards
Try using MX player. It plays pretty much any video format, no need to downscale or change video container. Works very well with subtitled and HD also.
** you may need to download an ARM plugin, MX will guide you through it.
