MP3 player recommendation please
RoyC
I know that there are loads around but without testing each one it is difficult and those I have tried don;t do what I want.
Essentially I need to :
a. define as source folder on the SD card which contains the mp3 files and it should always default to that.
b. Play those files in order.
c. Remember if I stop half way through so that I can, later, continue from that point.
d. Have the usual controls ; Play, stop , next , last, and to be able to drag the time to advance within a single playback.
Thanks in advance
Roy
Best is always subjective no matter what the topic. I really like 3 but it doesn't meet the OP's requirements A or B.
Actually, it meets every single one of them. You just have to have it configured correctly, which is very easy. Although maybe not that easy, because you obviously couldn't figure it out.
Thanks for your input. But when you're trying to give advice, at least make sure you know what you are talking about, which obviously, you do not.
