MP3 Tags
ZeneMG
Hi... can someone give me a link to bulk remove MP3 tags from my Android? All apps I see only do one at a time.
Zene
Thx for quick reply. I organize all songs the way they come without tags that show everything under the sun for song and title.
Default is artist, song title. I want everything organized that way. Hope this makes sense.
Zene
So they are organized by filename? I'm not familiar with a modern day player that sorts and displays file info by file name. Each into their own. I don't know of a tag remover. There are tag editors. I used one years ago to mass edit all of my tags (close to 60K tunes) to my liking. I first used an editor to change all of the file names in a consistent manner (artist-lp-title.mp3) Both were PC apps. I hope another has an Android tag remover to suggest.
Thx. To clarify, only one long list A to Z by artist. Pic shows problem.
Edit is the better term. It's really a pain to edit all the new stuff one at a time. Wondering if it wasn't a PC I used. Still think I did on phone, but lost app when I upgraded. Finally broke the PC habit 10 years ago after using for one close to 40 years.
Zene
Yes edit is the answer. An app to do it in batches. I wish I had an app I could suggest. I did my work on a PC. It was worth the effort. I hope another can hop in here with something to recommend.
I see there are a number of high rated MP3 tag editors at the Play Store. If push comes to shove, you can try one and delete it and try another if its not the tool you want. Good luck
