rock526
I updated my SM-910T (T-Mobile) to Marshmallow 6.0.1 a couple of weeks ago. Did a factory reset after the upgrade.
The multi-window panel with app shortcuts is not working correctly. It does not have a "handle" to grab. I want to move it to the right side of the screen and cannot. Also, the "create" function in the "more" menu is grayed out and inoperable.
You can see a gear icon in the notification bar in the attached screenshot. It does not have a corresponding entry on the notification window and I cannot make it go away. Not sure if it is involved in the multi-window problem.
Is this fixable or should I do another (painful) factory reset?
