Multi window
Any solution how to stop this problem
The multi window is always gonna be used in Recents.. That way ppl can see everything that's open. Only way I've found around that I'd to remove the access to Recent.. Which will be a bigger headache than leaving it alone. For more multi window options, enable Developer Options in the Settings and go thru that listing of options as they're usually there.
