Hello all
My mobile moto G4 plus showing multiple contact and some contact is mixed with other I reset my mobile but problems is remain. Pls help me thanks in advance
Log on to your Gmail account using a browser. From there you can view and edit your contacts - merge or delete duplicates for example. Or you could try your contacts apps settings, let it identify duplicates and suggest merges.
My guess is that a reset didn't fix it because you have all of the duplicates synced with Google, so when you cleared the phone and resynched it just downloaded the duplicates again.
After you reset your phone, where did your contacts come from? Are they stored on SIM card? Or did you set up Google accounts or other social apps again? On my phone, there are some duplicate contacts from sim card and WhatsApp.
