ciresiuol123
This will not allow you to multiboot yet, but if I can get this part figured out right, I will try my damndest to get the kernel in order. Needs a kernel that supports kexec-hardboot (just for the primary rom).
Also, help from other devs would be greatly appreciated considering that this is my first "real" attempt at anything like this.
I have attempted to port the Multirom recovery (TWRP-based) to the Avant. I can't test it because if it doesn't work, I have no access to a pc, so could not use Odin to re-flash stock recovery (or any working recovery).
I feel like it will work, though, but do not test unless you have a way to restore if it fails.
I am not responsible for any damages, blah, blah, blah, etc, etc...
Unzip and flash with either of these methods:
Flash on device with Flashfire app or through Odin on a PC...
You will also need Multirom Manager if/when we get the kernel sorted out.
