Help music player and calls have no sound without headphones
dfelder1
I have a samsung galaxy s blaze and the media players sound just stopped my phone still rings and everything but the only way i can hear my music or a caller is to wear headphones can someone help please because im not big on wearing headphones all day
A solution to a similar problem was to search for "wired headset routing fix" and download the app.
I had a problem with media starting and stopping, and no sound from youtube, although I had sound from ringtones, so I knew the physical speaker worked. After some research, I did a factory reset. No luck. I uninstalled all apps. No luck. So I did a 5 minute battery pull. No luck. Finally, I did an overnight battery pull = remove battery for 8 hours. Woke up, and assembled the battery to phone. My homescreen had 2 old icons that were right on right before I deleted the apps the night before. Maybe there is a buffer stack overflow in the droid deletion routine? (question for the devs). And so to continue, I started up my tunein radio and the sound and program work perfectly! Long story short, just try taking the battery out for 8 hours to fix your phone! ;-)
Thanks for contributing but this did not work for me. Still have no audio (excluding headphone use). The speaker does not work for any app, music, etc.
Does anyone have a fix?
