Music player for car.
thatperson
I am looking for a music play for when I am in the car. I have my X plugged into my aux input and would like a player that will leave the screen on so I can see the song playing and have access to the pause, back, and forward buttons without having to unlock the screen everytime. I know the car dock can do this, buy I can't use playlists with it.
It will be plugged into the charger so I'm not worried about running the battery dead. I can do this with Pandora and want some thing like it so I can play the music on my SD card.
Thanks for any help.
I'll have to take a look at tasker. I don't want to set the screen to stay on every time I get in the car. That would be a major pain in the you know what....
The Load N Go FM Transmitter allows you to listen to your music in any vehicle. The 512MB of onboard memory permits you to amount your music exactly from your computer onto the Load N Go, or use the included audio cable to avenue your MP3 player through the transmitter.
_______________________
herbal tea
I'm pretty sure he doesn't want another device to play his music, that's why he has an android phone. He just wanted a way to keep the screen on, and your post has nothing to do with that.
Yeah, I have my phone connected to my stereo with a cable running into a Aux input. I just want a player that will keep the screen on while playing and handle playlists.
