MXQ Android TV Box S805
  • Start date Start date
D
Deleted User
Guest
I have this MXQ android box that I believe is AMlogic. Its is an s805 if that helps.
I recently purchased a newer model (S905) and was going to use the S805 for another room. When I plugged in the S805 again the blue light was solid and I had no display. I tried on different TV's with different HDMI cables. I also tried using an AV cable. Also tried the AV reset option. Even tried the PSU from the S905 unit I had. No matter what I do I can;t get a display. I'm sure it's bricked but wanted to confirm and see if maybe there was a way I could reflash it. Can anyone assist?
If the blue light is shining then it could be working.
Have you tried a different HDMI cable or RCA cables?
Use the cable from your old box as you know that one works.
I tried different TV, hdmi cable and AV cable. Solid Blue light but no signal on TV. Also tried different PSU.
