Thisisconfusing
Very sorry for my bad typing learning disabilities very sorry thanks so much for your valuable time!
Okay not to make this to long, but some background on me. I'm a electronics tec,pcs, networking
The works, but I stopped after the pentium 4! So all these phones, tablets, i catch on fast but are
New and confusing!
A month ago me and my wife decided to drop cable, that's the first time i ever saw or heard of
These boxes! I have a good feel of it after a week, but it's android version 5 something.
The only service that beats cable TV is hulu! On my box it opens you can scroll up down and
Menus, But I try to play TV shows the commercials work everything until the show starts
Buffering the little circle spins a second then a generic won't play no details about it!
The ebay top rated seller says people can use it? I can't, and have tried everything.
I downloaded a rom flash specifically for the box, spent hours on YouTube learning,
Plus flashed hundreds of pcs,but this box is missing the hidden reset button. I opened
It and looked. I have forced adobe flash and whatever codec i could find. I went to
Settings fushd cache etc, uninstalled a bunch of times, i factory wiped it,20 calls to
Hulu, I ran a direct network cable to the box. Beats me I'm confused, only other thing
I can think of is turning the security off on the router.
I thought the higher the version that android was the more things you can run
And run better? Unless it's like the 8 core computer where almost nothing is made
To use that many cores! I have no clue about this box, kodi seems useless beats me
How to use it! They list so many things that these boxes supposedly do, but I have
Yet to find anything. Netflix is okay, but not the everything known to mz5hulu
Right now its just a TV tablet, because I have no idea how to use it!
I would really appreciate your valuable time to help me out
K~kK
Kmm
The number one thing is what's up with hulu? Fresh machine notb the
New and confusing!
K~kK
Kmm
