Help MXQ PRO 4K S905 WIFI PROBLEM
Hey every one iam having an issue with four boxes i bought for xmas gifts at local auction
the wifi dont work
Its a MXQ PRO 4K P201 5.5.1 The mother board reads s905q_v2.0 with the 8188etv real teck wifi chip
When i do find a rom that works with the wifi it wont see it only but the first time after a power down its never found again
I have found this firmware here to work as far as wifi issues go but other than that the system is slow and apps dont load its got some bugs here it is on google drive
https://drive.google.com/file/d/0B3C...xZMmMyTTA/view
I found this rom which works awesome except for the wifi
http://mediaboxent.com/mxq-pro-tv-box/
is there away some one could take the wifi from the one i uploaded to google drive
and add it to the media box rom the media box rom is very well put together with usb game pad support
any help would be greatly appreciated
thank you
I can give you a hack, go to your terminal and while as root type:
svc wifi disable
svc wifi enable
basically manually restart wifi, and it should get it working again. Don't know why the GUI interface doesn't do it but this does.
