My tv box will not let me turn back on the wifi connection. it will come on when i do the factory reset but if i restart the box it turns off and will not turn back on. I have updated the firmware to the latest MXQ firmware. I have a usb cable to connect to my pc. I have a usb disk drive if needed. I am at a loss. Can someone give me some more options? I can get my box to work on a 25 foot cat 5 cable stretched across my living room and hallway floor but is an inconvenience. I would my box to work as it is supposed to. I worked correctly for about a week then the wireless connection turned off.
