HollieLS
Hello!
I got the Mxq Pro 4k TV box this week.
The first few days it seemed to work fine but then all hell broke loose!
If I try to use Modbro it says 'no channels found, please try another language '
If I try Showbox, it will show me the movies but once I select one it says 'Server error'
If I try Kodi - nothing loads at all.
If I try to go to 'update & restore' it says 'check failed! Check your Ota servier argent '
Who can I fix this? It is driving me insane and I'm pretty close to returning the damn box
